Old 10-26-2021, 09:59 AM   #91 (permalink)
Piotrsko
Some outlets have gone dead, but the place hasn't burnt down. [shrug]
I may have a buyer for the VW Dasher, I'm thinking seriously about immediately sinking the proceeds into an Ecoflow DELTA. It would be the nucleus of a 1260 watt-hour
edit: Here's the Ecoflow DELTA: us.ecoflow.com/products/ecoflow-delta-portable-power-station.
My outlets typically go bad at the wall connections. Turn off the outlet and install a new one. I believe the '62 were first generation push ins. Since you're in a trailer, any chance the boxes are on metal studs? Then all you have to do is ground the trailer and attach new GFCI outlets that ground to the box (if they are in a box, trailers didn't necessarily meet code) Use a neon tester to check.
Like the mini power station but the comments are way past gushy to trust. Need. More. Research.
freebeard (10-26-2021)
