Old 10-26-2021, 12:56 PM   #50 (permalink)
freebeard
Originally Posted by Piotrsko
You do realize that RF is above 1mhz? All your computer stuff is technically short range RF, you just need antennas and receivers.
No kidding.
How to Build a Raspberry Pi FM Radio Transmitter
https://circuitdigest.com › microcontroller-projects › raspberry-pi-fm-transmitter
So by writing a code to perform frequency modulation using the spread-spectrum clock signal we can tweak the Pi to work as a FM transmitter. The modulated signal will be given out through the GPIO pin 4 of the Raspberry Pi. We can simply attach a normal wire of 20 cm maximum to this pin to act as an antenna.
One might be able to 3D print fractal antennae, but my print only does 0.2mm resolution.
