Originally Posted by tomi_k
This is first tuft test...
* side flank flow seeking lower pressure above roofline, as would be expected, but gentle intersections, no tuft 'flight', no obvious flow reversion, and probably zero attached vortex pair.
* adding side fairings, with Plexiglass fairings over the taillight lenses to the tail lid tail, which integrate around the top and bottom box radii surrounding the taillights would kill the separation bubbles, for a little additional drag reduction.
* a plan-taper tail section under the tailgate, even at the bottom with the diffuser upslope would optimize the whole kit.
Nice clean separation! The atmosphere thanks you and so do I. It'll be cool to see the underbody done up.
BamZipPow's Toyota T-100 diffuser section's attachment included the rear axle itself, and floated up and down with the suspension travel, simplifying gap issues for the belly pan. He's got a thread for it somewhere here at the Forum. If you haven't seen it, it 's worth a look.
Nice work!
