Old 10-29-2021, 10:56 AM   #633 (permalink)
aerohead
fins
Originally Posted by tomi_k View Post
Latest box with vertical fins... and changed top surface... this is the one which I used on my latest record (11.20 liters / 100km)...
Fins will be moved few inches "out" (closer to the tail lights) as I have room for it... and side fairing might show up ...
In a 90-degree, sidewind gust, the fin would be in the range of Cd 1.15, same as a sheet of plywood. That far back, behind the rear axle, she could present quite a yaw-moment, good, safety weather-vaning, flat-out at Bonneville, but maybe freaky out on the open road.
I've driven Spirit in pre- lethal, supercell cyclonic inflow, out in the Texas Panhandle, at 75-mph, and had no handling issues.
If you have a chance to safely test for stability, it would be very valuable data.
tomi_k (10-29-2021)
