Old 10-29-2021, 10:59 PM   #714 (permalink)
Xist
This house costs 25% more, but it is 72% bigger--not counting the 480 square foot block building with a 3/4 bath, the 120-square-foot shed, and it isn't much, but there is a 1-car carport.
It is a weird house and it needs work, but at least we have 12 pictures. That is six times as many as the other house!
While it needs work it qualifies for a conventional loan! That is vastly better than the other!
It is 20 miles and 24 minutes away, which is more than I would like, at least in that direction. It is in Snowflake, which is lower in elevation, so it is warmer. If I am going to have an outside-the-box home I want it in Pinetop-Lakeside, which is higher than Show Low, gets more snow, and is greener.
Pinetop-Lakeside is also on the other side of Home Depot, Lowe's, and our Walmart, while Snowflake just has a smaller Walmart.
It is only 3 miles from that Walmart, but 23 miles and 28 miles from Home Depot and Lowe's.
It is also on 1.53 acres, compared with 6,534 square feet for the other, so the property is over ten times as large!
The other is in the middle of the lot and surrounded by trees. You could add on here or there, but I don't think you could add a garage.
I am unsure that Google street view knows where the house is, but it just shows dead brush and bare trees.
The other location sure is prettier!
"Fresh exterior paint and new roof."
Nice!
There is a length of of gutter over the front door. I would replace it and maybe do gutters the rest of the way.
The metal under the fireplace is discolored. Can you polish out that?
The tile in the front room and kitchen look good. The cabinets are dated, but if I could remove the stains from the corners where they have been grabbed for 50 years, remove the child lock tabs from the fronts, and remove the paint from the tops, it would be okay.
There is something seriously wrong with the door frame. Hopefully spackle and paint would make it look okay.
The first bedroom has cheap carpet and is missing wall plates.
Laminate?
Vinyl plank?
The next bedroom has the tiniest ceiling fan that I have ever seen. The edges suggest they were trimmed. It also has a cheap carpet without anything by the door.
I don't know if the seventh picture is of the master bedroom or what. It isn't big enough for a bonus room!
It has cheap adhesive carpet tiles in one part and what looks like a remnant in another, with dated and mismatched ceiling fixtures.
There is also paint on the door.
The first bathroom is missing a drawer.
If that was the master bedroom the electrical box is in a closet.
Who does that?!
I wouldn't mind if it were in the side, but it is in the shelves!
I don't know where the water heater and furnace are, but it looks like they took the cabinet that went over someone's refrigerator and ran wires into it.
I want an electrician's opinion on the 10th picture!
The shed needs to be repainted and the door needs to be resurfaced, but that is barely larger than Mom's and it has a normal door!
I don't know how great that would work for storing stuff like lawnmowers, though.
The block building doesn't look like much and it is attached to the carport, which is even worse.
It isn't an attractive place for sure, but I could move in and start fixing it up right away!
$175,0003 bd1 ba1,099 sqft 2656 Paper Mill Rd, Taylor, AZ 85939
