Old 11-07-2021, 03:58 AM   #65 (permalink)
Juho
A small update, even though I haven't had any great success.
But atleast I do find it quite interesting what I have found with very high compression and E85
- about 16,5-17:1 static compression ratio
- +25bar cranking pressure - I only have a cranking pressure gauge for gasoline engines, and maximum is 21bars, and the needle went to whatever stopped it which is estimated about 25bars
- E85 fuel
- Vanos not in use; very late intake cam timing and advanced exhaust -- no overlap at all. Because I had to use stock cylinder head because of my crappy tooling.. otherwise I would have already in use the better head for the engine and vanos in use for both cams.
- knock sensor input almost disabled - caused a lot of odd behaviour, and knock sensors "see" the proper self ignition as "knock" ; atleast based on their signal / voltage on log files.
I was able to make the engine compression ignite properly at part throttle at highway speed, when the engine got heated enough (water temp 98-99ºC)
But it stopped when the lambda feedback got randomly turned off and mixture went about 5% more lean.
The engine started suddenly accelerating itself and went slight uphill with about 8L/100km momentary fuel consumption.
Which is quite promising.
They keys for compression ignition on ethanol seem to be:
- heat, heat and more heat.
I need to figure out how to heat intake air without egr, before I can finish the other cyl.head so I can have internal egr in use
- very sensitive of fuel mixture. If it knocks -> more lean mixture. Knock seems to mean at this engine the mixture burns way too early and all the energy gets wasted because of that.
- load, to 'light off' or run it on compression ignition "mode" - not too much ignition advance because otherwise it will knock very bad (like a diesel with injector timing way off)
- currently spark ignition still in use, to help it light off. It's very difficult to find what it actually wants. I had to go leaner than lambda=1.15 before I got rid of the knock on part throttle -- full throttle no problems
- and better mixing of the air-to-fuel mixture; this is where it wants tumble flow, which I do not have because of bad intake port design. My other cyl.head does have port shape to cause tumble flow.
- injectors; bosch ev14 12-hole injectors -- currently using stock 3 liter injectors, which have only 2 holes and running them 5bars fuel pressure. They do have "ok" fuel spray at the distance but I am sure the ev14 12-hole injectors help a lot.
Related pdf here: https://www.speed-talk.com/forum/vie...hp?f=1&t=63866
Running estimated lambda=1.60 mixture at the leanest. Stock engine max lean was 1.40-1.45 and it started missfiring. Lambda=1.60, no missfiring.
I had it on the max. (gas afr 22.4 / lambda=1.52), and went 10% leaner, which is why I guess it should be about 1.60
On the video I had lost a bit power, because going even leaner.
Earlier it could keep the speed with about 8L/100km momentary fuel consumption and sometimes required more throttle -> 9L/100km.
Only randomly it started igniting properly, assuming this because the mixture went slightly richer and injector pulse width was still the same and had more power.
Intake air temp only 11-12ºC. I'll see what improvements I could do.
And full throttle test on 3rd gear:
Some random pictures of engine:
I'm very surprised I haven't been able to cause any engine damage, that I could notice with compression pressure test, from spark plugs or looking through the spark plug holes what the top of pistons look like.
Even tho the engine has knocked very loud. But doesn't seem to be that dangerous to engine if it lasts only a short time and doesn't run on high load; e.g full throttle.
I'm also running on platinum spark plugs; NGK BKR6EQUP.
But it doesn't have enough platinum to cause catalyst ignition, which I would like to try.
Platinum glow plugs would be a good solution, but only available at too small sizes for the r/c car/boat/plane etc. engines which run on nitromethane or methanol.
It also seems like ethanol is actually more difficult to light off with a catalyst (platinum) than methanol.
Not 100% sure tho, but that's what I understood from what I found out.
I tried searching for glow plugs with platinum tip, similar to diesel glow plugs but it seems to be very hard to find information of materials used on glow plugs.
I did find out, that atleast Bosch glow plugs have inconel tip, which doesn't work as catalyst for ethanol.
But it is an option, to use a glow plug as hot spot to cause self ignition.
It could cause major problems at full throttle tho, if it ignites way too early.
And I am planning on installing a switch for ignition coils, to disable spark ignition when compression ignition is happening (well enough) to try it I could get the engine running only on compression ignition.
First I need to figure out how to get the compression ignition work better / more stable.
