Old 11-07-2021, 09:39 AM   #3 (permalink)
R.W.Dale
LE Camry - '03 toyota camry LE
90 day: 31.88 mpg (US)
Originally Posted by Joggernot View Post
When this happened to me it turned out to be a leak in the heater that put moisture to fog the windows and brought the smell of the antifreeze into the compartment. Might look for this.
After exhausting all other possibilities I came to this as well. However I'm not losing coolant and don't smell antifreeze. I dug in and changed the heater core anyway hosed out the evaporator, removed a double handful of wet rotten leaves and I think fixed a stuck recirc door. I even removed all the carpet and sound insulation
I'll know if I fixed it today
Too much junk to list. From a 10mpg caddy limo to a 5 speed Saturn
The Following User Says Thank You to R.W.Dale For This Useful Post:
Joggernot (11-07-2021)
