Old 11-07-2021, 07:12 PM   #65 (permalink)
S Keith
It'd be fine with a manual. I bet it wasn't offered with a CVT!
I just drove the car again. And before I started it, I opened the main fuse panel under the hood to see if there was something I could disable...
The only thing that looked promising was a fuse called "MG Clutch". I thought... "Motor/Generator clutch???" This could be fantastic! I pulled it.
Then I remembered the MG is not clutched in this version of IMA. (It is in the latest version, but not back in 2009).
I have no idea what MG Clutch means in this car.
There's a compressor clutch fuse in this car. I can't find anything in the service manual fuse information relating to "MG Clutch." Can you tell me from where you pulled it?
