Old 11-08-2021, 08:52 AM   #7 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by jeff88 View Post
Going the other direction... would decreasing the diameter speed up the air flow increasing power? (within reason of course, not downsizing to 1/2" or something)
What is too much? Is 1/4" within limits? Say 2-3/4" to 3" diameter pipe?
How does the Jeep run with the 1" larger pipe? Does it have more power, more "zip", better throttle response? Or just the opposite?
The question needs more information for clarity. Is the question in regards to everything in front of the throttle body or are you building a customer intake manifold?
If it is in front of the throttle body (stock throttle body) you can expect nearly zero gains. If you install a larger throttle body then yes, you may see better WOT performance but may suffer some part throttle drivability.
Also, what is your goal? What is the reason for the question?
