Old 11-08-2021, 12:52 PM   #41 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by EcoCivic View Post
Thanks. I don't think the hills I encounter on my daily commute are really long enough to be worth shutting the engine off for (1/2 to 3/4 mile of coasting at a time at the most), so the only EOC I normally do is shutting the engine off once I pull into my driveway and coasting into my garage.
If you track your MPG and get consistent numbers, you can easily try EOC and see how much difference it makes. 1/2 to 3/4 mile at a time sounds worth it to me. If you can estimate the total potential coasting distance with the engine off, add that distance to your miles and recalculate a tank to see the difference.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
EcoCivic (11-08-2021)
