Old 10-07-2008, 09:00 PM   #4 (permalink)
93Cobra#2771
The Green Hornet - '96 Ford Escort Wagon LX
90 day: 39.26 mpg (US)
The Red Rocket - '96 Geo Metro Base
90 day: 53.07 mpg (US)
cfg83 - you did go for a wider tire. A 195/65/15 is 10 mm wider than the stock 185/65/15 and slightly taller as you found.
What have you found in your mileage comparisons so far?
I'm wondering if the decreased deflection/ heat generation will cancel out any loss from the slightly wider tire? 10mm is less than 1/2" from sidewall to sidewall.
