Old 11-15-2021, 09:11 AM   #59 (permalink)
Piotrsko
Originally Posted by EcoCivic View Post
Interesting suggestion, I always thought floating gears was hard on synchronized transmissions and mostly only a viable option for unsynchronized transmissions. I don't intentionally float gears, but one time I forgot to use the clutch shifting from neutral into 5th gear and it slid in no problem.
Bada bing, there you go. I learned manuals on truck style non synchro boxes where being able to do this was a necessity. If the shifter slides with no issues it means the synchros aren't doing very much to alter gear speed.
After they synchro go bad you either have to do this or pull and rebuild it anyways.
EcoCivic (11-15-2021)
