Old 11-15-2021, 09:23 AM   #60 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by EcoCivic View Post
Interesting suggestion, I always thought floating gears was hard on synchronized transmissions and mostly only a viable option for unsynchronized transmissions. I don't intentionally float gears, but one time I forgot to use the clutch shifting from neutral into 5th gear and it slid in no problem.
Yeah, I'm pretty sure shifting without the clutch makes the synchros try to change the engine speed, versus just the input shaft speed. Of course if you can perfectly match revs every time, there won't be any wear. Rev matching with the clutch (and double-clutching) would be the best. My Insight demands this to downshift into 1st or 2nd gear. It'll growl at me if I don't!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
EcoCivic (11-15-2021)
