Old 11-17-2021, 10:44 AM   #58 (permalink)
The Toecutter
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
For various reasons relating to clearances and my own vehicle's unique dimensions, I won't be able to use your exact pattern/dimensions, and will need to make a pattern similar to above that meets my own unique requirements. What software did you use to generate the above?
I might be able to generate a faceted nose piece and continue to the transition point between laminar and turbulent flow, at least, and keep the rest as simple as the previous design.
