Old 11-17-2021, 07:44 PM   #8 (permalink)
Autobahnschleicher
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
Originally Posted by The_Techie_Stirlingite View Post
That is an order of magnitude more complicated, prone to failure, and expensive. As for the comment about engine load, I've seen 90-95% calculated load (before a transmission kick-down) when climbing hills on the interstate at 65 mph. 85% calculated load is not uncommon during normal acceleration.
I should measure my MAP when driving, but I rarely need that much load to stay in traffic.
However my car has some 150-160 PS/ton so that might be a factor.
Plus you could just shift down before reaching excessive loads.
My main issue is that I can't get enough load on my engine in normal driving.
