Old 11-19-2021, 07:11 AM   #31 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Wouldn't the overhead valve problem only apply if it has valve/piston interference? If there's no interference then the engine should technically still be able to run on the other cylinders. My dad once had a V8 with a valve stuck open and he kept driving on seven cylinders.
Unless the intake allows the spark to reach the manifold with a stuck intake valve. I remember my dad disconnected that one cylinder's sparkplug wire because he was afraid it would backfire up through the carb. Or maybe it was backfiring and wouldn't start as a result. I can't quite remember.
What I do remember is that it ran pretty well on seven cylinders, at least after he disconnected the sparkplug wire to that one cylinder with the stuck valve.
