Old 11-19-2021, 06:43 PM   #34 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
Wouldn't the overhead valve problem only apply if it has valve/piston interference? If there's no interference then the engine should technically still be able to run on the other cylinders. My dad once had a V8 with a valve stuck open and he kept driving on seven cylinders.
AFAIK nowadays most engines have interference.
