Old 11-20-2021, 10:00 PM   #68 (permalink)
EcoCivic
I accidentally tried engine off coasting earlier today (my knee hit the key and shut it off while I was coasting down hill at ~50 MPH). I tried to start it by shifting back into 5th gear which worked perfectly fine with no grinding. Not sure how it went into 5th gear perfectly from 0 RPM but kicked me out that time I tried to shift back into gear from idle. Could a bad/worn synchro work only intermittently?
