Old 11-20-2021, 10:28 PM   #69 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by EcoCivic View Post
I accidentally tried engine off coasting earlier today (my knee hit the key and shut it off while I was coasting down hill at ~50 MPH). I tried to start it by shifting back into 5th gear which worked perfectly fine with no grinding. Not sure how it went into 5th gear perfectly from 0 RPM but kicked me out that time I tried to shift back into gear from idle. Could a bad/worn synchro work only intermittently?
What's the weather been like? I've noticed that if the transmission is cold it can be harder to get things to mesh right in some cars. It might be the other way around in others. If one day it was cold and another hot, maybe that's the reason. Or if you had driven around long enough to warm it up that one time.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
EcoCivic (11-20-2021)
