Old 11-26-2021, 12:12 PM   #124 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
It is conventional wisdom for a reason. When I worked for a transaxle manufacturer we did accelerated differential testing by running different size tires.
How much damage you do depends on the difference in tire sizes and the design of the drivetrain. A simple open differential will take abuse much better than a differential with clutch packs like a LSD. The new fancy differentials that can selectively send power to individual wheels using clutches - you really don't want to burn up those clutch packs.
With an AWD car you are stressing two differentials by running an underside tire.
The Following User Says Thank You to JSH For This Useful Post:
redpoint5 (11-26-2021)
