Old 11-30-2021, 12:27 AM   #9 (permalink)
cRiPpLe_rOoStEr
Originally Posted by samwichse View Post
Makes sense to me to the have the turbo unit separate, even if it's basically just bolted to the side of a cast-in manifold.
Even if gassers became turbocharged by default, just like Diesels nowadays, it's worth to consider the cost of replacing a damaged turbo or upgrading it. There might also be some issues with thermal managementt of the engine. A cast-in turbocharger could maybe increase oil temperature through heat irradiation at the cylinder head for instance.
