Old 12-02-2021, 09:31 AM   #8 (permalink)
EcoCivic
Update: The block heater survived the night. Just not sure about what long term effects insulation may have on it. I think it should be fine since the element is still submerged in coolant but I'm no engineer.
As for whether it worked any better, it may have by a few degrees. Last night we had a low of 46 degrees and the coolant heated up to 101 degrees according to my Scangauge. Night before last, we had a low of 49 degrees and the coolant reached 100 degrees.
I certainly wouldn't call a 4 degree difference over a single test conclusive by any means though as many other variables as there could have been such as varying winds.
The Following 2 Users Say Thank You to EcoCivic For This Useful Post:
freebeard (12-02-2021), Piwoslaw (10-21-2022)
