So I promptly began fixing up the car, partly because it needs to pass an inspection and partly because I couldn’t not work on it. I patched together bits of the broken header panel and secured the headlights to the car, fabricated a totally blocked upper grille, pulled the dent out of the bumper (hole still needs zip tied shut) and used foil tape to cover the rust holes in the front fender arches and painted over it with black spray paint. I also installed turn signal bulbs and used clear tape to make lenses for the corner lights. So far it’s not pretty but it should work until I get my Saturn back on the road. Gotta say though, the thing is super comfy to drive, kinda like driving your living room down the road
My current Ecotec project...
My last Ecotec project...
