Old 12-09-2021, 12:53 PM   #89 (permalink)
aerohead
solid-state batteries
This is the prime issue about cell power density: massive energy transfer across low impedance makes things hot enough that the housing will not stop heat transfer into a very volatile compound.
I agree that if they used non flammable organic compounds there's less fire, but I'm not so sure the solid state batteries won't cause fires either.
Frank Markus, in his January 2022 MOTOR TREND 'Technologue' article, said that ' The ( physical expansion of the cathode ) expansion problem is shared with today's solid-state battery technologies and seems surmountable.'
Leading me to believe that it is certainly an issue, and the prize of success so great that, they'll continue to pour dollars into R&D, in hopes of overcoming the issue.
redpoint5 (12-09-2021)
