Old 12-13-2021, 11:36 AM   #14 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
Aerohead makes a good point. In the case of the Prius, eliminating the rear lift is only going to reduce a few pounds of drag. And that's assuming you manage to eliminate all the lift, without incurring a drag penalty. So realistically, reducing rear lift should be a secondary consideration.
The main purpose of a drag spoiler would be to clean up the rear wake. It's the same basic principle behind kammbacks and boat-tails. And it also appears to be what the spoiler in the OP is designed for.
The Following User Says Thank You to Blacktree For This Useful Post:
aerohead (12-13-2021)
