Old 12-15-2021, 09:48 PM   #407 (permalink)
racprops
The last very posts show why I will do full testing before really setting down to engerneer a device.
We need to do a proof of concept.
Propane has too little BTUs.
Nitrous Oxide (Nitrox) requires LOST of gasoline to work. It is mainly a hot rod power system.
Injectors are made to handle gasoline under pressure and to produce a fine spray.
Vapor will be a gaseous state and cannot be fed though fuel lines and injectors.
Most likely we will either add our own control system, we will not need a feed back loop, as we may not need to fine tune the fuel ratios.
Rich
The Following User Says Thank You to racprops For This Useful Post:
freebeard (12-16-2021)
