Old 12-16-2021, 03:43 PM   #413 (permalink)
racprops
There's abut the same difference between e10 versus e0 gasoline as there is propane versus gasoline.
Sounds like you want to go from a hypothesis straight to a finished product on the first try. Yeah it don't work like that.
OH I have a couple of designs.
One is said to work, but it is not something that can be manufactured and has a fixed flow rate, which means the fast you go the better the MPG get...up to a limit.
The other is my best idea, so there are a couple of starting points.
And I have a number of design notes, like when the car is turned off it just shuts off the fuel feed and the car will run until it burns off all vapor and then shut down.
And should anything fail it will automatic turn on the stock system.
And there are more ideas.
Rich
The Following User Says Thank You to racprops For This Useful Post:
freebeard (12-16-2021)
