Old 12-22-2021, 06:56 PM   #23 (permalink)
Autobahnschleicher
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
I thought everything injected has an excess fuel return line any more, the fuel pump should pump more than is needed to run full throttle so there needs to be a bypass somewhere that needs regulation. On the F250, you just add a #8 standard machine washer to the base of the filter housing.
I am not fluent in Toyota. But a programmwble ECU is just a regular ECU with access jacks, there are ways to access the programming because manufacturers need to sometimes modify the base software. On my VW, I can do it through the obd2 port but it leaves tracks that are illegal.
In case of the Spyder it is not possible to reprogramm the ECU.
People have tried for over 20 years, and it hasn't been done yet.
