Old 12-27-2021, 06:34 PM   #13 (permalink)
AviationMetalSmith
Had you considered vacuum molding? Here's an example on Polymetal of how you could blow and fold a box with rounded edges.
With a Polymetal monocoque might you eliminate the brazed frame?
I don’t know about polymetal. Do you mean a monocoque?
I figured out how to bend Coroplast, using a steam iron to heat the inside of the piece to about 320°F or 155°C. Recommend leaving a sheet of parchment paper between the iron and the plastic, just to be safe.
And I tried heating the outside , but that doesn’t work as good as heating the inside. I use an infrared thermometer to check that the sheet is hot enough all across along the line of the bend.
The Following User Says Thank You to AviationMetalSmith For This Useful Post:
aerohead (11-21-2022)
