Old 12-28-2021, 12:36 PM   #11 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Both test were ABA both directions on the road and mods on and mods off.
On the drive test I had temp setting to +29 celsius and more speed with the fan.
Stand by test Fan settings was only blowing to windshield and legs. The rear vents are under the drivers seat but the foam and the wall blocks that flow so you cannot get air going behind that glass. I will check if there is center vents for the rear seats, but I think not in my version.
I tested stand by mode fan speed at minimum and temp settings to 20 celsius. Car still stops the heat pump if the inside temp got too hot you dont need more fan speed. Outside temp was around +4 celsius only.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (01-06-2022)
