Old 12-31-2021, 03:49 PM   #24 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Would a wiring issue prevent my engine from idling above 1,500 RPM?
I asked to reschedule my appointments.
I think I only slept 1-2 hours last night.
Usually the crank sensor is used for timing below a certain speed, then camshaft sensor for the higher engine speeds. So, yes depending what the actual issue is.
Edit: I found this from a quick search, looks like the v-tech oil pressure switch and a transmission connector are very close.
https://www.justanswer.com/honda/3u9...-1500-rpm.html
That might place the issue in very close proximity to two symptoms.
