Old 01-04-2022, 09:31 AM   #58 (permalink)
Joggernot
Joggernot's Avatar
Originally Posted by Varn View Post
I always try and pick tires that have a tread no wider than the wheel rim width. Going bigger means that I will have a tire tread that is bowed a lot more and is subject to uneven wear particularly at higher pressures.
Let's see if I understand this. I have wheels that are 18 by 7. Does this mean you would only use tires that are ~178 mm wide? e.g. 178/70 R18? Recommended by the manufacturer (Honda) for these wheels is 235/60 R18. Per Discount Tire, the narrowest I can fit is 225/65 R18. DT doesn't allow searching for all tires that fit 18" wheels.
