Old 01-13-2022, 02:22 PM   #12 (permalink)
aerohead
trigger
I need to figure out how to trigger that state with a button because it's useful to have higher blade speed when picking up leaves.
Looking at the removed motor, there appears to be a dedicated lead entering the case, which might sense some eddy current back-EMF or something when 'loaded', signaling the inverter to transition to the higher power setting.
Mimicking that signal ought to trigger the same response.
They really 'mulch' better at the higher power, I can see how they'd do with the leaves.
