how do you intend to accurately measure fuel burn? The sensors I have seen seem to be +/- 20% and most demonstrators use a precisely calibrated fuel container and weigh the fuel at a controlled temperature
I suppose if you have a calibrated fuel flow map for injectors, accurate pressure measurement and record of the controller output, you could use that, maybe.
