Old 01-23-2022, 09:41 PM   #1 (permalink)
Xist
Linus tried TikTok Computer Hacks
Please note, these are hack tips, not actual hacks, but he found some to be useful, although they didn't necessarily give [correct] directions:
  1. Find an old DVR for $5, check the serial number on the bottom, and see if the hard drive inside, in a best-case scenario, is worth the cost of the purchase. Then buy security screw bits (oops!), and extract the hard drive, which hopefully works.
  2. Go to Ninite.com, select WinDirStat, download, install, run, and free up files you aren't using. They recovered 30 GB.
  3. Go to Prntsc/ and then any 2 letters, any 4 letters, and it will show you randomly-shared screenshots.
  4. Inspect element, go to "Console," write "document.designMode = "on" and press Enter you can edit almost anything on your page by just typing.
  5. Hide a folder in plain sight by changing the icon to something boring.
  6. [Doesn't work and there is no clear way to make it work]
  7. Get people to buy you stuff and then tell people what a great deal you got on it.
  8. Rig VLC to load a video when you boot your computer [and have a friend turn on your RGB lighting. Penny in the first season of "Big Bang Theory" said "Just buy a really cheap universal remote from Radio Shack."]. Go to SpiceWorks.com and follow the directions.
  9. Go into your BIOS and adjust your X.M.P. [D.O.C.P. on AMD] systems and speed up your computer--just hope your computer remains stable.
  10. Hit [Win] + V to enable your clipboard history and then you can paste anything you copied recently.
  11. Hit [Ctrl] + [Win] + [Shift] + B to reset your drivers and hopefully fix temporary problems. Someone remind me of this the next time Lappy forgets my wifi adapter--if only I had the wifi to look up the shortcut!
Yes, you seem to be able to edit any part of the webpage as if it were a text editor, but you are on your own with images:
