Old 01-24-2022, 01:55 PM   #8 (permalink)
freebeard
Z-index is an CSS element of HTML5.
https://www.w3schools.com › cssref › pr_pos_z-index.asp
Definition and Usage. The z-index property specifies the stack order of an element.. An element with greater stack order is always in front of an element with a lower stack order. Note: z-index only works on positioned elements (position: absolute, position: relative, position: fixed, or position: sticky) and flex items (elements that are direct children of display:flex elements).
You can try it out here: www.w3schools.com/cssref/tryit.asp?filename=trycss_zindex
