Old 01-25-2022, 08:33 AM   #5 (permalink)
fawad
Originally Posted by Vman455 View Post
The question is: will the guesses tell you anything about which wheel cover design actually has the lowest drag on your car?
The answer to that is "no." Get the one you think looks prettiest.
Hmm interesting. So it means I should stick with the OEM wheel cover that came with the car (check attached image).
Also, does this mean the wheel cover that came with the car is best? Since, I can assume they must have tested it with the car thoroughly.
The Following User Says Thank You to fawad For This Useful Post:
aerohead (01-27-2022)
