Old 01-30-2022, 05:01 AM   #7359 (permalink)
duncan2
Hi and low current
Hi mpgmike
The Paul & Sabrina IGBT power "bit" uses a ring capacitor and the current carrying parts made from copper sheet
There are enough drawings of that to lead me to believe that I could replicate that part
Paul also had a very smart solution to the issue that IGBTs are not identical - each one had about a meter of power cable - this ensures that they will "share" the current
So the high power bit is not the problem (I think)
The problem (to me) is the other bit - the low power "brain board" and the drivers for the IGBTs - and it may be possible to simply buy some IGBT drivers
I believe that an electronics/software guy would be able to make new "brain boards" - I certainly can't!!
