Old 01-30-2022, 08:33 PM   #76 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by EcoCivic View Post
Always used 5th gear to start it. When I was using pulse and glide I was usually bump starting it at between 40 and 50 MPH so around 1600-2000 RPM. When coasting to a stop with the engine off, I'd put it in 5th to start it once I'm down to around 15-20 MPH although I'm sure it would have started a bit lower than that. As you said, the engine doesn't have to spin very fast to start.
That might be a bit fast for bump starting. If I'm doing pulse and glide, 40-50 MPH is usually where I'd be shutting the engine off, not starting it. That could be why you didn't see an improvement in MPG too. I think it works better at lower speeds. I usually only coast to stops and downhill if it's not so steep that I need to brake. I tried a constant P&G in my old Civic and didn't see an improvement either. It might work better on overpowered cars, or at very low speeds.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
EcoCivic (01-30-2022), RedDevil (01-31-2022)
