Old 01-31-2022, 12:56 PM   #14 (permalink)
freebeard
DDG:
https://f.hubspotusercontent10.net › hubfs › 6205315 › Resources › Data Sheets › 20210624--Scalmalloy_Datasheet_Digital_F.pdf
SCALMALLOY® Description Scalmalloy is a powder product designed to be processed using laser-powder bed fusion (L-BPF) additive manufacturing. Due to high cooling rates and rapid solidification, a unique microstructure is achieved that rivals the performance of the highest-grade aluminum foundry products. Coupling these material properties with the
The chemical composition of Scalmalloy ® . | Download Table
https://www.researchgate.net › figure › The-chemical-composition-of-Scalmalloy-R_tbl2_322040277
Frank Walther. The second-generation aluminum-magnesium-scandium (Al-Mg-Sc) alloy, which is often referred to as Scalmalloy®, has been developed as a high-strength aluminum alloy for selective ...
So if it cracks or a tab breaks off you can't weld it.
My concern with AI designed lightweighting is going to be susceptible to nicks and scratches cascading to failure. Like the Wonderful One Hoss Shay
