Old 01-31-2022, 02:35 PM   #32 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Towing 8100lb from 5,000 ft to 11,000 ft elevation, at highway speeds, with temps in the 30's = 0.5 miles per kWh. I'm not sure what that tells me about realistic tow range but I guess we could use that as the absolute worst case scenario.
They say they are going to do another video with a more realistic tow with a more realistic payload vs a ICE truck.
True the first 90 miles of their trip there is relatively normal elevation changes, but after that they get pretty extreme:
Per this they go from 5000 to 12000ft. I thought I-49 was tough with an elevation change from 200 to 1800ft and a 15% grade. Ha
It will be interesting to see a test around 70F
https://www.flattestroute.com/Boulder-CO-to-Dillon-CO
So if you look you can see the get up to a 50% grade.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
