Old 01-31-2022, 07:15 PM   #35 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
That Rivian test was a failure. To say that was worst case is wrong too. I say get rid of a car hauler and put a 9000 pound box camper behind it 8' wide and 9' high with awnings and AC units sticking out and run it.
There was a problem with the downhill. They NEVER use cruise control so I don't know why the change. Any of the modern full size pickups will auto brake to maintain speed downhill if the cruise was set and obviously this Rivian was using the friction brakes. Probably why the brake lights kept coming on. It was only regen braking at about 20 kWh where supposedly it's capable of and that hill and weight would have used 150 kWh. Hopefully they will redo at least that part.
The Following User Says Thank You to Hersbird For This Useful Post:
aerohead (02-02-2022)
