Old 02-07-2022, 11:15 AM   #3 (permalink)
aerohead
Cd ?
I picked this thread because it had zero response and I want you to see this. I want to propose something to someone, and I seek your estimation.
A stock Arcimoto FUV weighs 1200lb and has 80HP. Koenigsegg has as new, very similar drivetrain that weighs 200lb and has 670HP www.motortrend.com/news/koenigsegg-gemera-quark-terrier-motor-specs-details/
I'm interested in a four-wheel class so add 200lb, 100 for drivetrain and 100 for a tandem bogey rear.
Assume a sub 0.20 Cd (Arcimoto front A-arm suspension), and 1400/670 power to weight ratio. For purposes of argumentation, what would the Cd be?
Sighard Hoerner would have us figure the CdA of each component, and add them together, along with a hook-vortice, 5% interference drag added to that total; then divide by the total frontal area. That's how Messerschmitt Aircraft Company used to do it. Hoerner worked for them.
Since the rear tandem wheels are almost completely wake-riding, they might be considered a freebie.
freebeard (02-07-2022)
