Old 02-07-2022, 02:38 PM   #33 (permalink)
aerohead
slide valve ..........Fish
I thought you might like it. The metering is via the backside of a D-shaped profile that draws in fuel into the airstream. And it has a slide valve instead of a butterfly, what does that do to pumping loses?
It reminds me of the notorious Fish carburetor.
Fish Carburetors – Ross Carburetors
Similar performance claimed, and altitude compensation. Six to ten discharge point is one difference.
They call it smart but it isn't an Internet of Things play.
All my motorcycles had cable-controlled or vacuum diaphragm-controlled slide-valve/ metering rod carbs.
Aerodynamically, I don't think that they're any improvement.
The hydro-electric dam bullet-valve and Junkers JUMO 004 jet turbine bullet- valves are probably the zenith of low-drag valve technology. I chose a facsimile for Spirit's cooling system.
The FISH carburetor lived up to some of the claims.
Push the vehicle up to 35-mph, bump-start the engine, and drive at 35-mph. There was no provision for acceleration or deceleration, just 35-mph.
