Old 02-07-2022, 05:15 PM   #34 (permalink)
freebeard
The hydro-electric dam bullet-valve and Junkers JUMO 004 jet turbine bullet- valves
If you have the [citation needed] you should submit it to Wikipedia. Their Jumo 004 entry has no mention.
Although it does cover my favorite starter --the two stroke APU with a pull handle. ...and the variable geometry Zwiebel:
On the original topic.I still struggle to explain the way it employs the Brayton Cycle. Apparently there is a high bypass airflow through the rotors' open hub, with each rotor being arrayed like the combustion chambers in a centrifugal flow jet engine.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
