Old 02-08-2022, 12:54 AM   #6 (permalink)
cRiPpLe_rOoStEr
Even better than ITBs is moving the "throttle" right to the valves. Honda's R series engines (2006+ Civic) vary the intake cam to control valve opening and therefore throttling, under some conditions.
Just think about Fiat's Multiair engines, or that Freevalve system.
It still has a throttle plate, but that gets held wide open when it changes to variable valve timing throttling.
On the newer iterations of the Fiat Multiair engine series, the throttle plate was retained mostly as a quick vacuum source for the brake booster.
Ecky (02-09-2022)
