Old 02-11-2022, 08:50 PM   #5 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The question could be asked: exactly how far can you go if you can ignore the ever increasing alarms? Also what would be pack voltage there? I have pushed my volt pack to 19 KWH by abusing the cells but I have no way of knowing if that damaged them. Being everything stayed typical, I don't believe I did.
From reading on the Bolt Forum - 0 miles. When the Battery Meter hits zero SOC and range hits 0 miles the car stops and says to shift into park. The battery isn't really at 0% SOC - it is at 5% - but GM has that last 5% locked away to protect the battery.
Cell voltage was was 2.8 to 3.0V for most cells but the total range was 0.4V
This is all before the recall software updates.
The Following User Says Thank You to JSH For This Useful Post:
aerohead (02-14-2022)
