Old 02-12-2022, 09:27 AM   #6 (permalink)
Piotrsko
Hmm so the low cells trigger the bms and you have a wider range of voltage mismatch. Wonder if they are cutting corners on the assemblies. If you turn it off, let it rest, does the SOC recover much?
any given day the maximum difference in my pack is only .2 volt between cells, pretty much the same cell locations charged or discharged. I tried a top balance, and a bottom balance and it didn't make any change worth noticing.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
aerohead (02-14-2022), tshire (12-03-2023)
