Thread: Thieves
Old 02-12-2022, 11:15 AM   #13 (permalink)
redpoint5
90 day: 51.16 mpg (US)
Are you going to add a bunch of UV lighting? Part of the difficulty is only the more sensitive pixels in the camera are producing signal which is why defination is so poor. Closer does get more pixels illuminated for a given target as does lighting it up.
I was thinking I should add some IR illumination. I need to research how best to do it, but I think using the IR built into the camera causes license plates and objects up close to get washed out. Instead I might setup an IR floodlight and try to illuminate a broader area more evenly.
