Old 02-16-2022, 09:14 AM   #15 (permalink)
Piotrsko
100% of my charging so far has been below 70 degrees. You asked for data charging below 40F. There are no temperatures below 40F in the 10 day forecast.
You're system is configured such that heaters come on below 70 degrees which did answer one implied question, but not whether your cells would actually charge at colder temps. The Volt pack I have will charge down to 32 but the process elongates horribly from 4 hours to 12
